nuheat floor mats wire hookup
Discussion in 'Electrical Forum discussion & Blog' started by KellyO, Dec 17, 2007.
  1. KellyO
    KellyO New Member
    Dec 17, 2007
    Hello,
    I am hooking up heated floor mats, by Nuheat, with their reccommended Thermostat. Question is when running the wires, from the mat to the power hookup, Should they be run directly into the wall and up to the box or do they need to be run on the outside of the wall up to the powersource? If the latter, how does one enclose the box? Is there a cover plate that will work? KellyO
  2. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    Electrical Contractor
    You notch the bottom plate of the wall, then run the wires inside the wall to the t'stat box. There should be a metal plate to install along the bottom plate to protect the wiring from nails, screws, etc.
    I cannot get any of NuHeats installation instructions to download at this time.
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Typically with floor heat, the line-voltage wires need to be protected somehow as they run up the wall.
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Did you read the instructions? The wires get snaked up the wall after the drywall is installed. Please read the directions.
  6. Steven62
    Steven62 New Member
    Aug 22, 2007
    Design Assistant, Watts Radiant
    Missouri
    Nu Heat
    I downloaded the pdf file for the Installation, and it does not show how to rough in the wiring. Go to www.suntouch.com and click the literature link on the home page. From here, go to manuals and guides, and click on elctrical rough -in. It will show a nice perspective view of a wall section and wire paths. Nu-heat is a bit different, but the basics are the same.
    I hope this helps!
Similar Threads: nuheat floor
Electrical Forum discussion & Blog New siding, lost power to 2nd floor Sep 16, 2015
Electrical Forum discussion & Blog Toe kick heater and flooring choice Mar 5, 2015
Electrical Forum discussion & Blog Heating the floor of your home's elevator: What is the Best Way Dec 21, 2014
Electrical Forum discussion & Blog Two 12-4 Romex cables through the same floor joist holes Jul 5, 2014
Electrical Forum discussion & Blog How much romex in 2" PVC conduit from 1st floor to 2nd floor? Jun 13, 2013
