NPT vs slip fit diverter handle spout
leorob
Los Angeles
I will be installing a Kohler 3 handle shower/tub Valve (K-303-K).
I have a choice of NPT or slip fit hardware. (K-T15231-4S or K-T15231-4).
I need help in deciding between the NPT and the slip fit.
Pros and Cons of each?
Thanks
It's much easier to get the slip-fit unit to snug up to the wall, and should work fine. But, if you use copper and tighten the set screw too tight, you can bend the pipe and give you grief later on.
