Novice looking for information on installing utility sink in basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pickngrin, Sep 5, 2009.
  1. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    I'm interested in installing a utility sink in my basement but have no idea about the requirements for the drain. Here is a photo of the drain pipe. I'm looking to do this cheaply.
    Am I able to drain the sink into this main drain pipe?
    Thanks
    [​IMG]
  2. Cass
    Cass Plumber
    Nov 12, 2005
    To do it easy It would have to connect to the ABS horizontal line but I don't know if it is low enough...
  4. hj
    drain
    The easy answer is YES. The hard one is that it is more than just cutting a tee into the pipe and hooking your sink to it. You do not know about plumbing so there may not be a "cheap" way to have a plumber do it correctly. There would also be issues with connecting it to the washer drain line to the left, even if it were low enough which it does not appear to be.
  5. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Thanks for the responses. I am going to call our plumber to see if it will be an expensive job (I don't want to invest a lot in this).
Similar Threads: Novice looking
Plumbing Forum, Professional & DIY Advice Embarking on whole house re-pipe as a novice Jul 14, 2016
Plumbing Forum, Professional & DIY Advice Novice...need some advice...loud screeching toilet Aug 25, 2015
Plumbing Forum, Professional & DIY Advice Venting system question from Eddie the Novice Nov 23, 2012
Plumbing Forum, Professional & DIY Advice Novice putting in basement bathroom Mar 27, 2009
Plumbing Forum, Professional & DIY Advice Laundry Room Plumbing novice (you will laugh hard!) Feb 27, 2009
