Notching and drilling
Jar546
USA
www.inspectpa.com
Bill Arden
Computer Programmer
MN, USA
www.billarden.com
Ok. So its another "Whats wrong here"
I'll point out the obvious and leave the rest to others.
The notched member is not reinforced.
The neighboring members are not doubled up.
Cwhyu2
Consultant
Cincinnati OH
I have never used pex and most of the pics that I have seen resemble this
pic though I have seen some neat ones.Is just the nature of the beast or
not knowing proper installation technices.
Redwood
Its called running home runs because they don't know how to size PEX tubing correctly. It doesn't need to look like that!
Construct30
NorthWest PA
Its call running home runs because they don't know how to size PEX tubing correctly. It doesn't need to look like that!
Someone really needs to find some pics of a proper manifold, home run, system and post them. I've seen some that look like art work they were so pretty. Due to flex for expansion and contraction it can't be made straight as copper, but it can still look neat and bundled. That's actually one of the biggest installation mistakes with PEX, you can't get it too straight and strap it too tight or you will cause problems.
Redwood
I don't like home running because of the spaggetti effect and the wait for hot water at every fixture.
In a large home I install mini manifolds for bathroom groups. It keeps the spaggetti under control and allows recirculation or, use of one fixture in that group to get the hot water there.
Redwood
No not at this time but I'll get you some... My Sony Camera is in the same class as Am. Std. Toilets and whirlpool water heaters... So I'm at a digital camera handicap right now. :(
Redwood
Thats about as good as a home run system can look. Still its a lot of spagetti for a 2 1/2 - 3 bath home. Which is why I would cut that back to fewer lines and use mini manifolds for bathroom groups.
Construct30
NorthWest PA
Redwood what brand and ... more details on that thing? That's a sweet setup.
jar546 thanks for a nice pic. I like the look of that one for a change.
