Not enough amps for Toto Neorest/Now what?
Discussion in 'Electrical Forum discussion & Blog' started by Janjan, Jan 4, 2010.
  1. Janjan
    Janjan New Member
    Jan 4, 2010
    Missouri
    I had decided on the Toto Neorest 500 for our remodel after my plumber said "no problem". The electrician just came to put in an outlet and said it won't support the watts for the Neorest. They had already pulled off of a bedroom for the heated floor and they said if they pull off anything else, if I plug in a vacuum, it may blow the circuit. I guess our house only has 15 amps circuits (with 20 for the kitchen). (Hope that all makes sense) They said I could an E200 or C110 washlet with a toilet, but now I don't know what to do. I had my "heart" and other things set on the Neorest. Advice please.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I assume you don't have any spare spaces in your panel, are you maxed out on power?
    [​IMG]
  4. Terry
    Aug 17, 2004
  5. Janjan
    Janjan New Member
    Jan 4, 2010
    Missouri
    Yes, we are maxed out on the power. I'm going to compromise and buy the E200 Washlet (410 watts)with either the Soiree or Guinevere. Electrician said it should be OK.
  6. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    If your panel is designed for it, and its a space issue and not a power draw issue, you can install tandem breakers which will let you install a new breaker where you couldn't before...
Similar Threads: enough amps
Electrical Forum discussion & Blog Is there enough power here Jul 19, 2009
Electrical Forum discussion & Blog tester prongs not long enough? Sep 9, 2008
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Friday at 9:21 PM
Electrical Forum discussion & Blog Pool Heat Pump and amps May 23, 2015
Electrical Forum discussion & Blog AMPS? Need Help.. Mar 14, 2014
