Not a weekend project anymore...subfloor questions...
Discussion in 'Remodel Forum & Blog' started by wwilson1, Apr 30, 2005.
  1. wwilson1
    wwilson1 New Member
    Apr 29, 2005
    Idaho
    I’ve been working on preparing a small bathroom for a tile install. The subfloor is ¾†plywood over I-beam type joists. There is a finished basement below. The joists are 16†on center and assuming they span about ½ the width of the house they are 16ft. Generally the floor seems fairly stiff except around a floor register (3â€x12â€) right where anyone will walk entering the bathroom. I can push down on the plywood near the register and see the floor deflect (1/16"?). What should I do? I hate to add a layer of plywood as this will put the final height of the tile way above (5/8"+new layer) the carpeted hallway.
    Options I’m kicking around:
    1. Suck it up and add a layer of whatever is the stiffest best subfloor based on your recommendations.
    2. Go in the basement and remove the drywall ceiling in the area below the plywood that is deflecting and try to back it up.
    3. Totally remove all (or part) of the plywood in the 60â€x84†floor area of the bathroom and install whatever is the best (low profile) subfloor?
    I’m not under any real time constraint, and want to do whatever is best; I do have a table saw etc. but limited expertise. Any advice would be appreciated.
    Thanks, Wayne
  2. jimbo
    jimbo Plumber
    1" subfloor thickness is considered minimum for tile installation. This can be achieved with 1/4" Hardibacker over the plywood. However, in you case the problem around the floor register is something else, and adding extra floor may not be enough. I would consider opening up the ceiling to see if you can box the area in with some 2X8 material.
    Between the backer board and the tile, you just have to suck up the fact that you will need to deal with issues like the flange, the doors, etc. Happens all the time.
  4. jadnashua
    www.johnbridge.com is dedicated to tiling. Check it out. You need to brace the area around the register. IF your joists are sufficient for tile, then you have a couple of options - the cbu then tile, or if you want to save a little in height, a product like Ditra by www.schluter.com. Note, what you need on the subfloor depends on whether the tile is ceramic or natural stone - stone needs twice the stiffness of ceramic. John's site can also help you out to determine the suitability of your floor - check out the "deflecto" on the tool bar of the forum.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    tile floors
    tile floors are always a problem on wood......
    if you really want to be a man, cut out all that plywood and install new 3/4 sup floor... but this is work....
    if you only have a small area that gives , its possible jsut to install another layer of 1/4 inch plywood or 3/8 over everything .....that is gonna make it pretty stiff
    its really youir call how downand dirty you want to get.
    personally I hate tile on wood floors... they seem always to finally move and give....
    it depends on how nice you want that room, I guess...
    vinyl sheet goods seem to hold up much better over time in an area that gets lots of use.
    good luck
Similar Threads: weekend project
Remodel Forum & Blog Adding stone veneer to basement project question.. Nov 30, 2014
Remodel Forum & Blog Bathroom remodel: Project management software Jan 14, 2014
Remodel Forum & Blog My Project: Ultimate Playhouse Dec 26, 2012
Remodel Forum & Blog project progress and electric panel issue May 4, 2012
Remodel Forum & Blog Bathroom Project Oct 15, 2008
