Norris One piece Toilet water seeping in the toilet bowl
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by shopping.deal, Apr 22, 2012.
  1. shopping.deal
    shopping.deal New Member
    Apr 17, 2012
    california
    Hi,
    We have been facing an issue of water seeping into toilet bowl forcing toilet tank to fill periodically - as water level goes down periodically. We replaced the flapper (blue rabbit ear one) multiple times w/o any success. We also tried cleaning the brass flush valve to remove sediments during the replacement of the flapper. We were thinking of replacing the toilets to avoid wasting the water but wanted to check if we can address the issue w/o replacing the toilet - as toilet it self is working fine. Note: This toilet must have installed during 1993.
    btw, we ensured the water is leaking into the bowl by putting colored dye (one get it from Ace Hardware) in the toilet tank.
    Would appreciate any pointers/help.
  2. jadnashua
    Rub your finger around the seal where the flapper goes...if it is rough or has a chip or lump on it, the flapper can't seal properly. Some flappers have both ears and a ring...if yours do, do NOT use both, cut the ring off so only the ears are holding the flapper...using both can often distort the thing, warping it and preventing it from sealing.
    Last thing, the gasket that is holding the flush valve assembly is held together with a big nut on the bottom of the tank. If that is loose or the gasket degraded, it can leak. You may just need to remove the tank and tighten the nut holding things in place.
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    note one piece toilets don't use that set up
  5. jimbo
    jimbo Plumber
    That is a builders graded toilet, probably not a good flush performer. But it can be fixed, and if you otherwise have no problem with it, you should fix it since a new one piece will be pricey.
    Look for 3 bolts outside the perimeter of the flush valve. Try just tightening them up. If that doesn't help, remove the flush valve ( held in by those screws) and get a new gasket, or a whole new valve/
  6. shopping.deal
    Apr 17, 2012
    california
    Hi,
    Thanks for the suggestion but I couldn't find 3 bolts that you mentioned. I'm attaching couple of photos of flush valve. Would appreciate if you have any suggestion on replacement part and/or how would it cost.
  7. shopping.deal
    Apr 17, 2012
    california
    Thanks. I definitely noticed the surface is not smooth. Not sure what caused it. Since it is a one piece toilet there are no nuts below the tank.
  8. jimbo
    jimbo Plumber
    Yuuuuuuuuuuup.... the seating surface is pitted. The big screw down there is what will remove the flush valve. You might even get away with dressing the seat with some emery.
  9. Lawrence Kahn
    Lawrence Kahn New Member
    Oct 2, 2014
    California
    I have two of these Norris toilets installed circa 1978. The Coast Foundry flush valve shown in the photos above came with a rather large gasket. Unfortunately, chloramene in our water has turned these gaskets into a tarry mess. The gaskets (washers?) now available simply can't seal because the hole in the porcelain is straight-sided. If I crank on the (admittedly very odd) attaching device in order to force the gasket to seal, it will probably destroy the porcelain. All the surfaces on my flush valve are smooth. I'd love to just replace these two one-piece toilets but I can't find one with an elongated bowl and a maximum height of 22 inches. What about an automotive product called Form-a-Gasket? This is really getting desperate; I didn't actually plan to spend my meager remaining time on the planet mucking about with this nonsense. I have NO PROBLEM with paying a professional to deal with this, but the best advice I've gotten is "replace the toilets". Great.
  10. Terry
    Aug 17, 2004
    I would check out a hardware store and see if you can find a washer for that.
    A little Silicone may help too.
    Though sometimes with a new washer, it's just a matter of making sure the porcelain inside the tank is smooth. A little emory cloth helps.
Similar Threads: Norris piece
Plumbing Forum, Professional & DIY Advice Norris Thermador toilet manufactured in 1965 needs replacement valve - What is the best one to use? Jun 24, 2015
Plumbing Forum, Professional & DIY Advice How to get hard plastic piece out of the drain? Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Fernco Repair Piece stuck under flange Oct 11, 2016
Plumbing Forum, Professional & DIY Advice Mold under shower pieces Oct 8, 2016
Plumbing Forum, Professional & DIY Advice Kitchen Sink Tailpiece/Strainer Sep 23, 2016
