Normal Softner Servicing?
Discussion in 'Water Softener Forum, Questions and Answers' started by sixgun95, May 23, 2012.
  1. sixgun95
    sixgun95 New Member
    Mar 19, 2012
    Scottsdale, AZ
    All new to me - When do you add salt? How much do you add? Installer told me but just want to make sure I understood correctly.
    Had my new softner put in based on recommendations here, unit & installer - couldn't be happier!
  2. Gary Slusser
    Retired
    What were you told?
    And what salt did he say you should use?
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Any water softener salt will work fine, solar crystal and pellet salts are usually fairly clean. Mined rock salt can be a little dirtier and may require regular cleaning of the brine tank.
    A regular household of 2 in your area should use approximately a 1/2 to a full bag of salt per month. Simply keep the brine tank full of salt and you are good to go. You should try to maintain the salt above the water level, but on modern timed refill systems, it is not a problem if the salt level gets below the water level accidentaly.
    Congrats on the new system! You will enjoy it.
  5. sixgun95
    sixgun95 New Member
    Mar 19, 2012
    Scottsdale, AZ
    When you see water coming level with salt to add. The container is about half full now and I can start seeing the water, seems early to ad salt but what do I know!
    I dont recall exactly what salt he said but its large pellets, I can look tonight. What do you recommend?
  6. sixgun95
    sixgun95 New Member
    Mar 19, 2012
    Scottsdale, AZ
    DITTOHEAD - You recommended the guy I used here in Scottsdale - awesome dude and excellent install!
  7. ditttohead
    Jan 9, 2012
    Ontario California
    Thanks, he is an old friend from 25 years ago when I started in this industry. He has worked for 3 of the major distribution houses in the US, and he was the technical support lead for 2 of them for many years. Be sure to refer him to your friends, he has a daughter to put through college. :)
Similar Threads: Normal Softner
Water Softener Forum, Questions and Answers Is it normal for water to smell odd after installing filter and softner Mar 5, 2016
Water Softener Forum, Questions and Answers Do I need to increase hose diameter for a longer than "normal" run? Jan 24, 2017
Water Softener Forum, Questions and Answers Normal after installing katalox light iron filter? Nov 25, 2016
Water Softener Forum, Questions and Answers Water Softener On = No Pressure, Bypass = Normal Pressure? Mar 7, 2011
Water Softener Forum, Questions and Answers no soft water even when regen seems normal. Jul 22, 2010
