Noob question about hot water heater
BrianLH
Seattle, WA
Our upstairs hot water heater (Rheem 81sv40D, fwiw) sprung a leak. We turned off the power and water while we wait 5 days for the insurance company to send someone out to look at it. Of course, it's still leaking (from the bottom) and causing water damage below.
Noob question: Does only water to be heated go through the hot water heater or does all of it? The reason I ask is that I want to drain the unit to stop the water leak, but do we open hot water taps or both?
Only water to be heated goes through the water heater. Usually there is a valve that you can close at the input to the water heater.
BrianLH
Seattle, WA
Yep, I closed that valve and drained the tank using the tap at the bottom of the tank. I was just curious if both temps travel through the tank. Thanks for the info!
If you have to wait days for the repair, I would take the water heater out of the loop, but installing a flex between the hot and cold.
Right now, anytime someone opens a faucet that mixes, you can get water from the hot side, which puts water back into your tank, even if the cold supply is shut off.
