NON IC rated lighting
Discussion in 'Electrical Forum discussion & Blog' started by bergyblue34, Mar 30, 2013.
  1. bergyblue34
    bergyblue34 New Member
    Mar 30, 2013
    Washington
    I have purchased halogen 4" non-ic lighting. I've come up with the novel idea of covering them with 10" clay pots to insulate and keep insulation off the housing. Anyone have an opinion? Question of the day, "Wht even make Non-IC lights at all? Where can you use them except in-between floors on a two story house. Oh brother.....
  2. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Check the instructions or contact the manufacturer. As I understand them non-IC are meant to be in open air. The pot may or may not have enough air volume.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    An IC fixture has a hi-temperature cut-out switch. If you put in too high a wattage bulb, the temp. switch will cause the lamp to turn off and on every few minutes. If the fixture in this example was non-IC....you just get to call the fire department!
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    If you keep the pot far enough away from the whole fixture it will work fine. No different than making sheetrock boxes and covering them (which was common back in the day).
    I can tell you a 10" pot will NOT cut it. More like 18" or 20". And then it will strain the ceiling sheetrock pretty good.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    There are prefabricated boxes for this purpose. I have seen nice ones made from 2" XPS. As stated above, the can must have a good amount of free airspace around it.
  7. hj
    IT must not only have "free air space" around it, but also "air flow" to remove the heat buildup, which means it should be "open" to the atmosphere.
  8. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Where is this rule written?
  9. jadnashua
    Keep in mind that you can solder wires with a 12W iron - slowly, but it can be done...solder melts at a significantly higher temp than the combustion point of wood or paper. The instructions on all fixtures like this I've ever seen tell you the 'keep-away' distances. Best practice, buy IC rated ones, regardless, and don't worry about it!
  10. jimbo
    jimbo Plumber
    San Diego, CA
    Here is a spec sheet for a Halo 7" remodel can, non-IC. Requires 3" on all sides. Other models could be different.
    It DOES have a self-resetting thermal protector.
    http://hi.atgimg.com/pdf/93/h7rt.pdf
  11. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    No kidding. Why bother otherwise?
  12. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I am curious as to what solder has to do with it. THere is no solder in a recessed can.
    That keep away distance is typically 3" like Jimbo wrote. I've never seen any other rules about it. Do you know of any, officially?
  13. ckl111
    ckl111 Home Builder
    Apr 23, 2009
    Home Builder
    Ontario
    You answered your own question. You use IC lights in an insulated ceiling and a non-IC light everywhere else. You can use an IC light everywhere else too but it is a waste of money.
    Insulation contact (IC) lights are designed to be air-tight so that it doesn't leak warm, moist air from the house into the cold attic and condense into water in the winter. If you live in Florida you won't have this problem but if you live in a cold climate, you will. They tie into the vapour barrier of the house in new construction.
    They are more expensive than their non-IC counterparts. Most IC potlights nowadays already come in a big metallic box that can be buried in blown-in insulation. Read the manufacturers instructions including the approved trims that go with the can. Enclosed trims like a shower light usually specify a lower wattage bulb. Local inspector may also have their own requirements.
    There are some "retrofit" IC potlights that can be in direct contact with insulation. http://www.cooperindustries.com/content/dam/public/lighting/products/documents/halo/spec_sheets/adv042450_ei700rat.pdf It's really not worth the hassle to make a non-IC potlight suitable for use in an insulated ceiling.
    All quality potlights have temperature sensors whether they are IC or non-IC. It's a fire protection issue. The only time I have ever had problems with the temperature sensor constantly turning the light off was when the ceiling was spray foamed. The spray foam was TOO good at insulating so it retained too much heat in the can. If I have to foam a ceiling, I wrap the light in fiberglass insulation to keep the foam off the potlights.
  14. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    I just love it when the customer changes the bulbs and installs bulbs that are larger than what is called for. In such a case I charge for a service call being it was not the fault of the installation or the equipment. I am easy but I am not cheap
  15. jadnashua
    My point on solder was that it doesn't take much wattage to generate enough heat to make things dangerous. Most solder melts in the 400+-degree range, and wood/cellulose, and a lot of other things will burn at lower temps than that. IOW, it doesn't take much to make enough heat in an insulated space to make a fire hazard. For sound insulation, and where you may want to close off say the second floor, you may want insulation in all of your ceilings...using an IC-contact fixture is in the noise pricewise compared to the labor and risk should you need to get insulation in there for whatever reason on a non-contact one.
  16. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    I saw it written somewhere that it is no longer allowed to build a sheetrock (tm?) enclosure around non-IC fixtures. Can't remember where, though...
  17. MushCreek
    MushCreek New Member
    Apr 30, 2013
    Travelers Rest SC
    IC rated 6" cans are currently $5.50 at the big box stores- that's pretty cheap.
  18. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Brand?? If it's Commercial electric I'll pass thank you.
Similar Threads: rated lighting
Electrical Forum discussion & Blog Recessed Lighting And Fire Rated Ceiling Jun 21, 2008
Electrical Forum discussion & Blog Seperated Lighting and Plug Circuits Oct 19, 2007
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
Electrical Forum discussion & Blog Electric baseboard: 80% rated circuit load, and wire ampacity May 25, 2016
Electrical Forum discussion & Blog Fan rated ceiling boxes Sep 2, 2013
