noisy return air duct
Discussion in 'HVAC Heating & Cooling' started by Master Brian, Feb 9, 2010.
  1. Master Brian
    Master Brian DIY Senior Member
    Nov 13, 2008
    Kansas
    My furnace sits right below my dining room. Due to the design, part of my floor joist cavity in this area is part of the return air system and a couple of the joist bays have been covered with sheet metal to create the duct channel. The problem is whenever you walk in certain areas, you can hear the metal flexing and popping.
    I am curious, could I replace that metal with something else like ductboard or drywall? Or would possibly adding some of that sticky duct insulation deaden the sound?
    Thanks....
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Wrapping the outside may help some. I wouldn't replace it with ductboard or drywall, you would likely decrease the size of the duct and that stuff doesn't clean real well.
  4. Cookie
    Cookie .
    Oct 7, 2005
    Brian, I had the same problem but in my bathroom. It was flexing and popping. What I did was nail the sheet metal down tighter right around the top where it fits in the register, it hasn't made a noise in 3 years now.
Similar Threads: noisy return
HVAC Heating & Cooling Pressure locked return manifold Sep 24, 2016
HVAC Heating & Cooling Shifting Supply & Return Main Trunks over 3' Apr 10, 2015
HVAC Heating & Cooling Enlarging/replacing main cold air return vent Apr 6, 2015
HVAC Heating & Cooling Chilly Finished Basement Needs Cold Return? Mar 26, 2014
HVAC Heating & Cooling Can forced air supply duct be run through panned returns? Oct 28, 2013
