Noisy PRV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Randyj, Aug 19, 2010.
  1. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Is there a solution to noisy pressure regulator valves? I was on a job last week that one of the customer complaints is a noise from the water heater. I found that the PRV is next to the water heater and is the source of the noise. It really makes a racket when the washing machine is filling. When I slowly closed the valve to the water heater the noise slowly diminished. The incoming water pressure is 150 PSI and the line pressure on the other side of the PRV is 50 PSI. The plumbing in this house is very high quality work to code, built in the 1980's, all copper pipe. The PRV is free standing (not in the ground) and is mounted on the water supply line in the basement of the house. The house is also outfitted with a solar water heating unit which is some 15 to 20 feet from the PRV. Oh yeah, water supply shut off valve is a ball valve as is most valves on the system other than some of the supply stop valves and the bibs for the washing machine which is about 30 ft from the PRV.
  2. jimbo
    jimbo Plumber
    Probably need to rebuild the PRV
  4. hj
    Is the PRV installed backwards? That WILL cause a shrill noise.
  5. Randyj
    Nov 25, 2006
    Alabama
    that was the first thing I looked for... might be worth taking a second look at it to see if I looked at it correctly.
Similar Threads: Noisy
Plumbing Forum, Professional & DIY Advice Noisy copper pipes Jan 14, 2016
Plumbing Forum, Professional & DIY Advice NEW TOTO DRAKE 1.6 G-MAX noisy fill? Dec 17, 2013
Plumbing Forum, Professional & DIY Advice Noisy plumbing Apr 12, 2012
Plumbing Forum, Professional & DIY Advice Noisy wastepipe in wall Jan 23, 2012
Plumbing Forum, Professional & DIY Advice noisy studor vents only when it's cold Feb 22, 2011
