Noisy Porcher
Discussion in 'Toilet Forum discussions' started by jdwatson, Jun 24, 2008.
  1. jdwatson
    jdwatson New Member
    Jun 24, 2008
    I have a Porcher toilet in my master bathroom that is keeping me awake. It makes a flushing-like sound about every half an hour. It sounds like pressure is being released. How do I fix this? I have no plumbing skills, so I'm hoping for an easy fix.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It is an easy fix... All you need is a new flapper! is this a 3.5 or, a 1.6 gallon per flush toilet?
  4. jdwatson
    jdwatson New Member
    Jun 24, 2008
    Thank you. It's a 1.6 gallon per flush.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Get yourself one of these and install it,
    http://www.korky.com/Flapper2004BP.html
    [​IMG]
    Before you take the old one out make a finger mark on the inside of the tank where the water lavel falls to whan the flapper closes when you flush. You want to set this flapper to close at the same tank water level.
    Also your flapper should hang on 2 hooks. If that is the case you need to cut the ring off the new flapper before installing it. You do not use both the ring and the hooks to install this.
    This flapper should be available at almost any hardware store or at big orange/blue box stores too.
  6. jdwatson
    jdwatson New Member
    Jun 24, 2008
    Thanks for the help. I'll give it a try.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Post back if you have any problems... Or, even if you want a pat on the back when you are done!
Similar Threads: Noisy Porcher
Toilet Forum discussions Noisy Main Stack pipe Dec 8, 2013
Toilet Forum discussions Noisy toilets Nov 6, 2012
Toilet Forum discussions BioBidet very noisy fill cycle? Aug 25, 2010
Toilet Forum discussions noisy water pipe after flushing Jul 7, 2009
Toilet Forum discussions Are All Pressure Assist Toilet Noisy? May 26, 2007
