Spokaloo
Alright, the pressure from the wife has been exerted to a high enough degree that I need a longer term solution.
Currently have a 1.5HP Grundfos submersible in a well that's between 40 and 60 ft deep. All copper run to a pressure tank in a detached garage (40 gallons). Copper then runs through the ground and into our domestic at the foundation, and into an all copper distribution system in our house that was built in 1981. Right now, there's enough vibration when the well pump is running to cause a ton of noise. The builder did a mediocre job of retaining the pipe in the walls, so when we get vibration, it sounds like someone is operating a grinder in the house on a metal drum. No kidding, 30 db in some places.
I either need a solution to damp the vibration in the system between the pump and the house, or to replace the pump completely with a new setup.
Where it becomes complicated is we operate a well water fed 5.5 ton WaterFurnace geothermal heat pump with a desuperheater that feeds our hot water, and discharges the water out to the lake behind our home. Obviously we don't just have a standard domestic water need with showers and washing equipment, but we also flow water up to 24 hours a day on the coldest days of winter through the heat pump.
I had looked at a variable speed pump for this amount of water, but haven't seen remarkable reviews about the setups.
Any assistance with either knocking down the vibration or going with a new pump would be greatly appreciated.
E
E
