Noisy Boiler Pump
Discussion in 'Boiler Forum' started by Kiko, Dec 1, 2013.
  1. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    My boiler pump is an Armstrong (probably 1/12 HP.) All the other pumps in the pump room are Bell and Gossett. There are 8 apts served by the boiler.
    This Armstrong pump was jack-hammering, so I asked the maintenance man to replace the coupler, and the jack-hammering stopped. However, it is still too noisy. The noise vibrates into my apartment. I made a recording of it, in case anyone can determine what still needs to be replaced in this noisy pump.
    http://soundcloud.com/kiko98-1/noisy-pump-mp3
  2. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    Update: The apartment manager thinks this noise is "normal" and won't fix it. At night, you can hear the noise throughout the entire apartment, and this pump is noisier than all the others. If someone can diagnose the problem from the audio clip (in the above post), at least I'll have a chance of getting it fixed. If not, I may have to hire someone and pay for it myself. It's driving me crazy.
  4. mage182
    mage182 Member
    Feb 17, 2011
    New York
    This happened to me in a similar situation. It turned out a small chunk of debris that was lodged in one of my radiators found its way down into the pump housing and was bouncing around. After removing it the problem continued and turned out in the end to be some gunk that was built up in one side of the impeller causing it to be imbalanced. Once I cleaned the entire housing and impeller thoroughly the noise disappeared.
  5. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    Thanks Mage, Giving it a good cleaning is sound advice.
    I'm still waiting for some of our resident boiler experts to chime in with their ideas.
    Could it be the motor is overheating, a bad impeller or bad bearings?
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    It sounds like a bad bearing assembly which includes the impeller.
  7. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I was looking at some youtube videos, and the boiler expert said that whenever you replace the coupler you should replace the motor mount. I know the maint guy did not replace the motor mount. Could a bad motor mount be causing this noise (by causing the motor shaft and bearing assembly shaft to not line up with each other correctly)? That would be a lot cheaper than replacing the bearing assembly.
  8. Tom Sawyer
    Nov 29, 2010
    Maine
    personally, I'd replace the whole circulator with a Taco 007 cartridge type. Damn near silent, but no, replacing the motor mount? He could get rid of the old four spring coupling and go with a siongle spring. Google spring coupling for B&G / Armstrong
  9. BadgerBoilerMN
    BadgerBoilerMN Hydronic Heating Designer
    Mar 4, 2011
    hydronic heating designer/contractor
    Minneapolis
    Yes, definitely an inline wet rotor.
Similar Threads: Noisy Boiler
Boiler Forum Noisy baseboards...air in system? Nov 29, 2015
Boiler Forum Noisy Taco 007 Circulator Nov 21, 2011
Boiler Forum Need help understanding and adjusting temp on boiler system pics included Feb 14, 2017
Boiler Forum Triangle tube boiler, ignoring demands for space heating Feb 9, 2017
Boiler Forum Adding basement zone to hydronic boiler / enclosing boiler Feb 5, 2017
