noises from bathtub
madjic
recently in our top floor bathroom when you flush the toilet there is a gurgling sound from the drain of the bathtub....any ideas what is going on???
Plumber1
Florida
gurgle
Must be a restriction downstream of the connection between the two.
Or the drain is trying to breathe some air....Check the vent too.
madjic
vent
how do i check the vent.....or......what do i do with the vent????
Plumber1
Florida
noise
Go on the roof to that vent that is gurgling and have someone flush that toilet and listen for gurgling. If it gurgles, the drain is partially plugged. And that means you need to clean out the sewer. If you don't hear any water flowing , then the vent may be plugged. It's not likely but it could be.
