noise in shower head
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by blove1344, Jan 17, 2013.
  1. blove1344
    blove1344 New Member
    Sep 8, 2012
    retired engineering civil designer
    New Cumberland,PA
    My newely installed tub/shower has a squealling noise when the shower is turned on.
    It is a Moen valve and shower head and there is a loud squealling noise usually after
    the water has been on awhile. Then goes away and comes back later. It almost always
    makes this noise when you are shutting off the water. I changed shower heads but that
    did not solve the problem. I'm wondering if it is the valve itself of should I try another
    shower head? Has anyone else had this problem?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Squealing noise can propagate through the piping. One of the most common "squealers" is a main pressure regulating valve, located near the main house shut-off valve. You might look for that, and see if it is the source.
  4. blove1344
    Sep 8, 2012
    New Cumberland,PA
    We are on a well system. I checked the tank pressure and it reads 50psi.
  5. jadnashua
    Is there a tub/shower with a diverter in the tub spout? Those can be notorious for making some nasty noises. Most can't be repaired...replace it. Try playing with the knob on the diverter on the tub spout to see if you can change the sound if you have one.
  6. blove1344
    Sep 8, 2012
    New Cumberland,PA
    Thanks Jim,
    It is the diverter! I'd never thought of that. I was ready to swap out the valve.
    Thanks again!
  7. jadnashua
    One of the more reliable designs out there is made by Delta. The ones that have a ring around the spout that you pull DOWN to activate the diverter. They have them in many styles and finishes, but you may need to deal with the fitting to attach it. They do make a bunch of versions, though. You sometimes have to instruct guests on how to activate it, though.
  8. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    "You sometimes have to instruct guests on how to activate it, though. "
    LOL ;) I went to visit my buddy in Kentucky and that's what he had to do, lol. I never saw one like that, but I like it though.
Similar Threads: noise shower
Plumbing Forum, Professional & DIY Advice Shower faucet noise, only when water is flowing through the spout Nov 28, 2014
Plumbing Forum, Professional & DIY Advice 3 Stem Shower - Hot Water Causing Noise When Partially Cracked Open Oct 14, 2008
Plumbing Forum, Professional & DIY Advice Seeking help to reduce noise from shower drain Apr 20, 2008
Plumbing Forum, Professional & DIY Advice shower drain noise Sep 26, 2007
Plumbing Forum, Professional & DIY Advice Lound Banging Noise with sngle handle shower valve!!! May 25, 2007
