prestohelp
I am hearing noise (sounds like running water) in the pipes behind our two toilets (where the shut off valve is)as well as in the pipes behind one bathroom sink. I checked the meter at the street before leaving for the day and it was on the same number when I got back home several hours later so its not registering water use. I still hear the noise if I shut off the water at the street. The toilet bowl and tank are not dropping / losing water level. We did have a clog two weeks ago and the plumber installed a 2 way cleanout behind the house in the backyard and I believe he snaked the vent as well. That is when I started hearing this sound all the time....after the work was complete. It sounds just like water running in the pipes, but again, no water use being registered. So, what am I hearing then?
Any insight would be most appreciated. Thanks.
