Eurob
master tile and stone installer
johnfrwhipple said:I'm no engineer but the pressure had to be off the charts. Kind of makes me worried about my flood tests. If you where to flood test with the ____ membrane and that shower had one of the large pre-made curbs. And you filled it to the top of the curb.
All future testing will be much clearer in the verbiage or wording. I will not reference any ANSI this. Not a single TCNA that. Nor any TTMAC jargon.... In BIG BOLD LETTERS I will call this style "Whipple Style"...
If I remember correctly -- Nuke's post -- the pressure for a 36'' x 36'' filled with water , 1'' would be 1psi , 2'' would be 2psi and so forth , but I think it is at the lowest part where the drain connection is , NOT at the changes of planes -- where the pressure would be smaller --......but I may be wrong . If I am not , the pressure would be negligible and the leaks would be from wicking .
For future testing I think we should call the shower flood tests -- Whipple 1O1 Test -- . Kinda curious that this small requirement is not covered by a standard reference .
johnfrwhipple said:On a side note I was called a couple weeks back from Dural.
I just browsed through -- I think Dural's membrane -- and some reference to flexibility and foundation wording was mentioned . Am I having the right membrane ?
