No water second floor,help!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tiffkbjf, Apr 17, 2013.
  1. tiffkbjf
    tiffkbjf New Member
    Apr 17, 2013
    I purchase a forclosure. I recently turned on the water. The first floor seems fine dispite the toilet problems. The second floor however isnt getting any water, toilet, sink, nothing. Its a multi unit. Ive turned on every basement valve. What else is there?
  2. jadnashua
    There may be an additional valve somewhere upstairs. This would be desirable to be able to service it without impacting the first floor tenant. Maybe in a utility room, behind a panel, in a closet...hard to say. The other, much more problematic, is that maybe during the winter, the heat was off, the pipe split, and it's running in the wall(s) somewhere. With everything off, check the water meter (assuming you have one) and see if it is registering any water flow. If it is, shut off the main, then go searching!
Similar Threads: water second
Plumbing Forum, Professional & DIY Advice If It’s Not Broken Why Replace It 18 YO water heater on second floor Apr 16, 2016
Plumbing Forum, Professional & DIY Advice Hot water only working for a few seconds Jan 16, 2014
Plumbing Forum, Professional & DIY Advice Hot water goes cold after a few seconds even after installing new water heater Dec 31, 2012
Plumbing Forum, Professional & DIY Advice pfister lav faucet water flow cuts out after 10 seconds Feb 8, 2012
Plumbing Forum, Professional & DIY Advice Faucet whistles for a few seconds anytime water runs in the house. Sep 6, 2010
