No water running
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by theclueless, Jul 27, 2009.
  1. theclueless
    theclueless New Member
    Jul 27, 2009
    I had recently purchased a property that the water had been turned off due to unpaid bill. After the bank paid the city and cleared the full payment certificate, I went to the city water department to have them turn the water back on, but they told me they never turned the water off, all I need to do is to hire a licensed plumber to turn the water on. The plumber turned on the buffalo box valve on the curb and the main water valve inside the house, there is still no water.
    Anyone ever experienced anything like this? Or suggest what the problem might be? If I need to get the city to check the buffalo box valve, that is going to take weeks, and I don't want to pay premium to plumbers to check the pipes and valves if the problem is not the main water valve... Thanks in advance.
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    No Water
    The plumber turned on the buffalo box valve....I assume thats what in the N.E. is called a curb stop?, and turned the main water valve in the house, where is the meter located?, I think I'm missing some info.:confused:
  4. theclueless
    Jul 27, 2009
    yes, the buffalo box is the curb box, and we have meterless account
    the setup is like this: city pipe (sewer) - buffalo box (sidewalk) - main pipe (under front yard) - main valve (crawlspace) - house pipes
    so somewhere from buffalo box to main valve is broken, I really hope the problem is not the main pipe (lead pipe, really old)
  5. hj
    water
    The only way the lead pipe could be "broken" would be if a root encased the pipe and squeezed it shut, (I have only seen it happen a couple of times). Otherwise, if the Buffalo Box valve is open, (and hopefully he did not turn it 180 degrees which would have turned it off again), and your main valve is open, there is no reason you should not have water. The only other place the water could be shut off would be the corporation cock on the water main, and they would have had to dig a hole to turn that off.
Similar Threads: water running
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Wednesday at 6:13 AM
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Running Easy Heat Freeze Free Water Heat Pipe Cable Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Running hePex on Hot Water Tank Nov 3, 2016
Plumbing Forum, Professional & DIY Advice Water is running slow Sep 20, 2016
