No water pressure!!!
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by tthurston, Oct 18, 2011.
  1. tthurston
    tthurston New Member
    Oct 18, 2011
    Michigan
    I bought a cabin in July and the water system ran good. They system has an above ground pump. I had the water lines inside all replaced. I then noticed that the water pressure would drop after about 5 minutes in the shower. The problem has gotten worse. I replaced the pressure switch and the bladder tank with no luck. The pump constanly runs and I have no water pressure. I did notice that when I shut the valve between the bladder tank and the house, the pump shuts off like normal. With the valve open, I can hear noise in the pipe between the house and the bladder tank. Is this an indication that the line between the house and the bladder tank has a leak? Any help is greatly appreciated.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You have a leak somewhere after that shutoff valve.
Similar Threads: water pressure
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Sunday at 7:40 AM
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure trouble shooting Nov 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Complete redo of water plant - replace pressure tank with CSV Oct 17, 2016
