No water pressure on hot side in shower
Discussion in 'Shower & Bathtub Forum & Blog' started by PlumbingNewb, Sep 5, 2007.
  1. PlumbingNewb
    PlumbingNewb New Member
    Sep 5, 2007
    I have the handle that goes around in a full circle from cold to hot in my guest shower. When I turn it to cold I get normal cold water, but when I turn it all the way to hot it basically shuts off and nothing comes out.
    I have a washer/dryer 2 stories below this room and it seems that in the guest bath under this room it sounds like water is constantly running in the pipes. I can't find any shutoff valves etc. so I don't know what to look for. All the other hot water is working in the kitchen, guest bath, and master bath.
    Thanks for your help!!!!!! :)
  2. jadnashua
    It helps to know the brand and model.
    If it is a pressure balanced valve (required on all newer construction), then the spool may be stuck. Can't say if it can be cleaned up and would then work or if it needs to be replaced. There may be other things going on here.
    Explain more about when and where you hear water running.
  4. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    with all your fixtures off, check the water meter to see if it's moving. if so, there is a leak somewhere. you can also turn off the valve at the water heater and see if the sound stops. this probably won't solve the "no hot water issue" but will get us going.
  5. PlumbingNewb
    Sep 5, 2007
    Thanks I'll try that. I don't think there is a leak though because my water bill is like $40 something a month and I take 2 showers a day so its not outrageous.
    The shower handle on off looks like this:
    I can't put a link so try this:
    Moen Legend One Handle Chrome Shower Only Faucet
    Model L3175
    at home depot website
    What should I do?
  6. PlumbingNewb
    Sep 5, 2007
    If I remove the handle is there anything you suspect I can turn to open it up behind the wall like a valve or something?
  7. PlumbingNewb
    Sep 5, 2007
    shamless bump... just need to know if I unscrew this thing if anything bad can happen and if I can actually get the valve open for hot water somehow even though I can't see one until maybe I open the thing up.
  8. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Shut off the water and take the valve apart...
    see if you can get the spool inside loosened up - use some plumber's grease on it...
    If the innards seem worn, take them to a good plumbing supply shop and get some replacements... Buy genuine Moen parts... no knockoffs
  9. PlumbingNewb
    Sep 5, 2007
    :confused: ok I got the faucet off ok and behind the part you turn there are two little knobs you can turn with a flathead screwdriver. Should I mess with those? Maybe they are closed? There seemed to be a lot of drywall over one of these. I'm assuming they are hot and cold valves or something. What do I do??!!?!
  10. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    They are built in shut off's for the shower valve. I'm thinking that whom ever installed the shower valve did not set the high limit for the valve. If the high limit is set to high on delta valves when you turn it all the way on the pressure will drop almost like if you went to far and your starting to close it again.
    I would adjust that and i think this will solve your problem.
  11. PlumbingNewb
    Sep 5, 2007
    Thanks, I turned the right one and it turned the cold water off. When I turn the shower handle to hot, nothing comes out even when I turn the one on the left which I assume is for the hot water. The sink and everywhere else gets hot water. Should I open up the valve on the left that must control the hot water and try to clean it? There is hardly any room to do anything in there without breaking the tile.
    That water running like I said above is only once in a while, may be my neighbors or something also, not sure. Its a townhouse.
  12. PlumbingNewb
    Sep 5, 2007
    Here is a pic of what I'm talking about, see attached
  13. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    It is a pressure balance valve. You should have no water coming out if you turn the water off on either side it is a safety feature.
    just make sure the hot is open all the way or if you are thinking of opening the wall make sure the water is off all the way hot and cold
  14. PlumbingNewb
    Sep 5, 2007
    I put it in the open position and every other position while the water was turned on and nothing comes out... What is the next step to try? Thanks
  15. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Do not open the valve unless you know the house main is off. On the new style single handle shower valves if you turn off one side and not the other the water will not come out no mater how much you turn the shower valve. It can fool you and is very dangerous. So to play it safe turn off the house main
    All shut off valve are righty tighty lefty loosy.
  16. PlumbingNewb
    Sep 5, 2007
    Thanks, I'll make sure to turn it off. When you say open the valve what am I doing and trying to accomplish? The middle piece?
  17. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Sorry I just didn't want you to think that if no water is coming out it would be ok to open the valve as in take it apart.
  18. PlumbingNewb
    Sep 5, 2007
    It doesn't look like there is really room for me to take much apart there without busting tile. What would a plumber check next to see what the problem is?
  19. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    The first thing is to make sure both hot and cold shut offs are on. The next thing to do is take the valve apart to see if something is blocking the flow. there really is not much to do about this unless you find that some valve (shut off) is not open all the way. Taking apart a shower valve can be very easy or very hard. Some valves can be fixed by replacing one piece some many pieces. Can you tell what brand the valve is. Sometimes the manufacture will send you new parts free.
  20. PlumbingNewb
    Sep 5, 2007
    I'm not really sure where to go from here to take the valve apart. I'm sure you guys would know what to do... What should I try to do? Snap off that HC white piece of plastic or what? I have no idea what to do with this
    Thanks!!
  21. PlumbingNewb
    Sep 5, 2007
    What brand do you think this valve is? Maybe their website may have more info if someone can help me with that
Similar Threads: water pressure
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Occasional Low Water Pressure Jan 19, 2016
Shower & Bathtub Forum & Blog Concern of water pressure on well for dual shower head setup Dec 5, 2015
Shower & Bathtub Forum & Blog Tub Water Pressure Help... Sep 28, 2015
Shower & Bathtub Forum & Blog Drop in water pressure when flushing toilet Jul 18, 2015
