no water pressure in kitchen
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LM, Jun 2, 2008.
  1. LM
    LM New Member
    Jun 2, 2008
    We just disconnected one of the water heaters in our house. We never understood why the previous owners had two installed and feel that one should be sufficient. The old water heater was removed successfully, but now we have little or no water pressure in the kitchen. All other rooms are fine. Any ideas? Thanks for your help!:confused:
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    A good place to start would be to check the kitchen sink faucet aerator... It may have plugged up with debris from the work being done.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The reason there were two heater was the previous owners did not get enough hot water from a single tank. Rather than scraping one one small tank and buying a larger tank, the connected a less expensive small tank in series with the first one thereby giving them the benefits of a large tank for the price of a small one and not having to scrape a the first small tank. As Redwood says, check the aerator in the sink faucet and probably all of the others while you are at it. Also check to make sure the shut off valve at the tank is fully open.
Similar Threads: water pressure
Plumbing Forum, Professional & DIY Advice Fluctuation of water pressure Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Boiler shutting off... water pressure? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Low water pressure upstairs Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water Pressure Regulating Valve Question Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Disinfect new water pressure tank? Jan 8, 2017
