No water out of the faucet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by trawlerphil, Apr 25, 2013.
  1. trawlerphil
    trawlerphil New Member
    Apr 25, 2013
    North Carolina
    The fact is I’m not too proud to show my ignorance. I must have changed out a whole bunch of these $20 Lowes faucets over the years in my rental units and boats, but this one has me stumped. It started when the hot water would come out for a microsecond and then stop, even with the faucet wide open. I shut off the water to the faucets under the sink and figured it was the faucet itself. I took the plunger apart, cleaned everything and put it back together, same result, no hot water.
    I disconnected the water lines to the faucets, removed the entire faucet assembly and replaced it with a brand new $20 unit, connected everything, turned on the water valves and voila-- same problem with the new faucet!
    Logically, this leaves two potential bad-boys, a bad on/off water valve, or a defective faucet unit. I did crack the water valve a bit while it was disconnected and water came out.
    Color me stumped! Any thoughts?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Use a supply hose on the angle stop and flush the line into a bucket. This will prove water is available and flush any debris that might be in the line.
  4. hj
    Why didn't you check for water flow from the supply lines BEFORE you replaced the faucet? Or at least blow through the faucet with the valves open to see if it was plugged up? My customers would go ballistic if I started replacing things before I even knew what, or where, the problem REALLY was.
  5. Terry
    Aug 17, 2004
    Are you using the Watts Flood Safe connectors?
    They shut off the water if there is too much flow. If so, chuck them and put on standard supplies.
  6. jadnashua
    If it's a multi-turn shutoff at the wall, it might be the washer.
Similar Threads: water faucet
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Today at 6:03 AM
Plumbing Forum, Professional & DIY Advice Bathroom faucets only trickling water, kitchen is fine Jan 4, 2017
Plumbing Forum, Professional & DIY Advice Reduced Water Flow in Single Bathtub Faucet Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Explosive water at faucets. Jul 29, 2016
Plumbing Forum, Professional & DIY Advice Water leaking from the bathtub near the faucet Jul 27, 2016
