no water, no sound when I turn spigot
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Roberts, Jan 22, 2011.
  1. Roberts
    Roberts New Member
    Jan 22, 2011
    Laurel, MD
    We just bought a mobile home. Within the first month the water had frozen in the pipes twice due to the heat tape shorting out.
    Last night, however, my husband used the restroom in the middle of the night and discovered we had no water. The first thing we do now is check the heating tape. It was on and warm, so yay there. Still, no water.
    We also don't hear that gurgling sound we had heard when the pipes froze previously. I've turned off the hot water heater because I don't want the thing to burn up or blow up. Do you have any ideas why there is no water if the heat tape is still working? The temperature is in the 20s, but it has gone lower than this without the pipes freezing before.
    Thanks.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The pipe can freeze anywhere, including below where it goes into the ground at the shut off. If the heat tape is not installed and working for the entire length, it can and will freeze.
    The heat from the trailer will keep the space underneath above freezing if the skirting is insulated and sealed up well to prevent air leakage.
  4. hj
    The pipe will freeze ANYWHERE it gets cold enough if the heat tape is NOT applied to the pipe there.
Similar Threads: water sound
Plumbing Forum, Professional & DIY Advice Tap/clunk sound from water line (not water hammer) Feb 28, 2017
Plumbing Forum, Professional & DIY Advice Banging/Knocking sound when tenants flush. Water Hammer Arrestors have been installed. HELP Please! Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Knocking sound when hot water is turned on Jul 10, 2016
Plumbing Forum, Professional & DIY Advice Kohler K-596 Faucet Hot Water Whirring Sound Jan 30, 2016
Plumbing Forum, Professional & DIY Advice Water pipes sound like someone blowing across the mouth of a glass coke bottle Jan 13, 2016
