No Soft Water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sbcoach, May 5, 2007.
  1. sbcoach
    sbcoach New Member
    May 3, 2007
    I have a Kenmore water softener that was run out of salt. Not a new thing. This time after refilling the salt and regenerating a few days there still is no soft water. Everything seems to be working correctly in the regeneration cycle but still no soft water. Ideas??
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Call Sears, if it's still under warranty. I myself use an independant treatment guy to test water and design the systems. Your salt setting may be too low. It may need to be set to regenerate more often.
  4. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    You probably have a water heater full of hard water. It will take a while to refill with soft water.
  5. Gary Slusser
    Retired
    Is the water in the brine tank higher than normal?
    Is there water running to drain in a regeneration?
    Check the operation and troubleshooting sections here:
    www.kenmorewater.com.
Similar Threads: Soft Water
Plumbing Forum, Professional & DIY Advice Water softener problem after power outage Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Water softener Radiant heating question Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Low Volume Water Softener (8 gal./week) Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Advice on water softening (or not). Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Water Softener Recharge Drain Dec 28, 2016
