No soft water after filter change on a Kinetico
Discussion in 'Water Softener Forum, Questions and Answers' started by Tony Foran, Feb 24, 2010.
  1. Tony Foran
    Tony Foran New Member
    Feb 21, 2010
    mi
    I swapped out the pre filter and now I'm only getting water if the softener is by-passed. Do I have air in the system? What I'm I missing?
    Thanks for any help,Tony
  2. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    There is a plastic rocker inside the valve that, if broken, will not allow water thru the unit. I have a picture of it but don't know how to post it.
  4. Tony Foran
    Feb 21, 2010
    mi
    It worked fine before the filter change but now I only have water on by-pass. I could have damaged the valve somehow?
  5. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    What kind of bypass for the kinetico?
    Did you bleed the air out of the pre filter after the filter change?
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Skippy, you have to go advanced so you have all the posting options. There is a thing looks like a paper clip, that's for attaching photo's.
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    Is that plastic part that easy to break?
    Is it one of them that if you look at it wrong it breaks?
  8. Tony Foran
    Feb 21, 2010
    mi
    No, I did not.
  9. Tony Foran
    Feb 21, 2010
    mi
    That did it! Thanks a lot for the help.
  10. Akpsdvan
    Dec 29, 2009
    Alaska
    If this was in Alaska I would be saying
    Strange things happen in the land of the midnight sun.
    Why a ball valve is not used before and after a pre-filter is still a strange thing to me.
  11. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    Yes the plastic rocker can break at anytime. When broken, it causes both pistons to close shutting off the water supply. The rocker is the ones in the upper right side of the pic (small piece). Thanks for the help.
  12. Akpsdvan
    Dec 29, 2009
    Alaska
    Brake at ANY time?
    Och....
    Is it a fail safe idea?
    Why would some thing that could cause that much trouble still be in use?
  13. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    IIRC when it switches tank, the rocker forces the opposit piston to close preventing water flow from the tank in regen. They do break easily with age.
  14. Akpsdvan
    Dec 29, 2009
    Alaska
    Every unit has its weak point..
Similar Threads: soft water
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Sunday at 12:24 PM
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
Water Softener Forum, Questions and Answers Water Softener & Whole House Filtration Feb 8, 2017
Water Softener Forum, Questions and Answers Is my watersoftener broken? Jan 29, 2017
