No Room For P-Trap on Washer Standpipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DigitalJim, Aug 7, 2009.
  1. DigitalJim
    DigitalJim New Member
    Aug 7, 2009
    Engineer
    Rochester, NY
    I am moving my washer 12' and installing a new 2" drain. Due to the placement of the washer box, a standard off-the-shelf p-trap won't fit without cutting out a large portion of the stud (vertical of p-trap falls in line with stud).
    Is there any reason why a built up p-trap using 90 deg elbows would not be allowed and/or recommended? Also, is there a width limitation on a trap? I would have to extend the width on the bottom of the trap about 3" to pass through the stud.
    Thanks in advance for any comments.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Why not pass through the stud with the vertical waste and then install the trap?
    [​IMG]
  4. Terry
    Aug 17, 2004
    Exactly.
    Just place the p-trap within the stud space, and use two 45 els up to the box.
  5. DigitalJim
    Aug 7, 2009
    Engineer
    Rochester, NY
    I'll have to check the clearance, but I believe I can do that.
Similar Threads: Room P-Trap
Plumbing Forum, Professional & DIY Advice Bathroom Sink P-trap backup and glug sound "un-vented" Monday at 2:27 PM
Plumbing Forum, Professional & DIY Advice Bathroom Sink leak at P-trap Jun 28, 2015
Plumbing Forum, Professional & DIY Advice Can I use the existing P-Trap for this bathroom reno Dec 2, 2013
Plumbing Forum, Professional & DIY Advice P-trap issue - Is it possible to switch washing machine and bathroom sink locations? Aug 30, 2010
Plumbing Forum, Professional & DIY Advice How can I add a p-trap to finally resolve stinky laundry room! Oct 4, 2009
