No regeneration?
Discussion in 'Water Softener Forum, Questions and Answers' started by martinf55, Jul 23, 2012.
  1. martinf55
    martinf55 New Member
    Jun 7, 2012
    Brampton, ON.
    Ive had my Fleck 3600sxt for a month now and it hasn't regenerated yet. I have it set to regenerate every 14 days or earlier if needed. Can't figure it out?????
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Is it drawing brine ? Have you cycled the valve and checked that you have suction at the brine line?
  4. ditttohead
    Jan 9, 2012
    Ontario California
    3600SXT? Well, I assume you mean the 5600SXT since the 3600 was never available in electronic form, and it was discontinued about a decade ago...
    A common problem with newly installed systems is the turbine in the meter can get a piece of teflon tape, debris, etc inside of it. Do you see the meter indicator flashing when water is flowing?
  5. martinf55
    Jun 7, 2012
    Brampton, ON.
    Did a manual regeneration and BW flashing then stopped when time countdown started.
  6. ditttohead
    Jan 9, 2012
    Ontario California
    On the SXT screen, right hand side, you should see a water drip (not the faucet) and it should blink when you turn on water inside the house. The system must be in service (not regeneration). I assume your system is a metered 5600SXT. Check that first and let us know what you find.
  7. martinf55
    Jun 7, 2012
    Brampton, ON.
    Have to wait for initiated regeneration to stop. Want to see it go through stages. I'm pretty sure that water drip flashes.
Similar Threads: regeneration
Water Softener Forum, Questions and Answers Katalox Light regeneration using Chlorine solution Feb 17, 2017
Water Softener Forum, Questions and Answers How long before forced regeneration? Feb 5, 2017
Water Softener Forum, Questions and Answers How to set regeneration time on a 5600 Econominder Jan 23, 2017
Water Softener Forum, Questions and Answers Fleck 5600stx, having several gallons of rusty water after regeneration Dec 1, 2016
Water Softener Forum, Questions and Answers Fleck 9100SXT Regeneration problem Nov 17, 2016
