No regeneration - turbine problem?
Discussion in 'Water Softener Forum, Questions and Answers' started by SteveW, Oct 6, 2011.
  1. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I installed a Kenmore softener about 2 weeks ago. I have noticed that it hasn't regenerated since I manually regenerated it after installation. I put it into diagnostic mode to see if it is measuring water flow, and it does show that it is sensing flow, but compared to my previous Kenmore softeners, it does not seem to be measuring water flow accurately. The digits don't run up very fast even with a faucet fully open, but instead they go up about every 2 seconds or so.
    I took the turbine out and it spins on its axle just fine.
    Any ideas? Seems to me it is acting like it is binding up when actually installed (the turbine, that is) because it spins just fine when out of the housing.
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    You might try only putting it back in just enough and then putting the bypass back in place and see if that helps.
    It is possible that the turbine is getting pushed to far into the housing and thus not able to spin as free as it should.
    Water passing through it should push it more to the bypass fitting.
  4. SteveW
    Feb 11, 2005
    Omaha, NE
    Thanks -- good point, will try that.
  5. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Check and see if the magnets are out just a tad. The will bind causing it not to spin.
  6. SteveW
    Feb 11, 2005
    Omaha, NE
    I pulled the unit again today and again the turbine spins just fine on its axle when it's out of the softener. When I put it back into the softener, I left it out just a little and then pushed the bypass tubes into the softener, then pulled it apart again - it caused the turbine and housing to seat fully in the same place where it was before.
    The magnets are flush, too.
    I'm stumped. I wonder if the electronics are bad? That doesn't seem to be a likely failure mode (that it would read some pulses but not all pulses) but who knows?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    One thing to check, it is a little tricky because you are trying to hold the turbine while holding the sensor end over the turbine and blow... if the turbine spins and the flow shows up on the display then I would say that the turbine blades are not right from the factory, they are a bit long and hitting the housing that they should be clearing.
    Now if the spinning does not show up on the display, it could be the sensor is bad and not getting the full signal.
  8. Akpsdvan
    Dec 29, 2009
    Alaska
Similar Threads: regeneration turbine
Water Softener Forum, Questions and Answers Clack WS1 regeneration question . . . Mar 5, 2017
Water Softener Forum, Questions and Answers Katalox Light regeneration using Chlorine solution Feb 17, 2017
Water Softener Forum, Questions and Answers How long before forced regeneration? Feb 5, 2017
Water Softener Forum, Questions and Answers How to set regeneration time on a 5600 Econominder Jan 23, 2017
Water Softener Forum, Questions and Answers Fleck 5600stx, having several gallons of rusty water after regeneration Dec 1, 2016
