no pressure
Discussion in 'Irrigation / Sprinkler Forum' started by tunderkoffler, Jul 19, 2007.
  1. tunderkoffler
    tunderkoffler New Member
    Jul 19, 2007
    I've just recently moved into a house with an inground sprinkler system with 9 zones. zones 1,4,5,6,7,8, and 9 work properly with good pressure zone 2 has barley any pressure and zone 3 works at about half pressure what should I be looking for or checking other any help would be great:confused:
  2. CHH
    CHH New Member
    May 25, 2007
    Denver, CO
    Well, I'd say it's good news that most of the zones work well which means that there is good flow rate and pressure at the zone valve manifold.
    Troubleshooting should go step by step. Manually open zone valves 2 & 3 and see if the there is still low flow. If the flow is good then there is probably a problem with the valve actuator.
    If the flow is low then disconnect the discharge end of the valve and check the flow when you manually open the valve. If the flow is good then the problem is between the valve and the first sprinkler head. Replacing the pipe is probably the simplest solution. If the flow is low then either repair or replace the valve.
    The big box stores and many hardware stores have replacement parts for the major brands.
  4. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    Normally if it is only 1 or two zones operating with low pressure, I start looking for a leak. This may or may not be in the pipe itself, it could be a broken riser (the threaded nipple that connects the heads to the pipe), or a broken coupling etc.
    Turn on the zone manually, by either using the bleed lever if equipped, or by loosening the valve solenoid about a 1/2 turn.
    Start walking around from head to head wiggling each head to look for water coming from places it is not suppose to be. Maybe let it run a while to see if you can get a leak to come to the surface. Watch for lumps in your lawn that were not there before. If you have good turf, it can expand like a water balloon!
    There are other less common problems that it could be, a pinched line from roots, clogged line from debris, or a faulty valve.
    Do the suspect zones have more heads than the rest?
  5. tunderkoffler
    Jul 19, 2007
    still no pressure
    I've check all the valves and replaced them it had minimal effect and then I found that zones 1 through 5 run off a different well connection then 6 through 9 and that there was also a zone 10 zones 6 through 10 have amazing water pressure compared to any of the other zones if there is a master valve could that not be working properly:confused: Any more thoughts on it would be great:D
Similar Threads: pressure
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
