No Pressure Water Starts and Stops Need Help
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by webbfamily2008, Dec 6, 2007.
  1. webbfamily2008
    webbfamily2008 New Member
    Dec 6, 2007
    I really need help. I bought this home 3 years ago. This home shares a well with another home. I don't know anything about wells. I need help to know where to start looking for the problem. Our well is about 100 yards from our house. We have a submerged pump. The water is pumped uphill to our house straight from the pump. The water on the farthest end of the house starts and stops constantly. It does seem to help a little if I turn on the cold water first. We don't have a reservation tank. I know I don't have half these words right. I really need to learn the basics of well pumps and air pressure to figure this out. My large bath tub is the main problem and I miss it dearly. The shower in the same bathroom works fine but the water to the tub starts and stops continuously. It takes about an hour for the tub to fill half full. I also have problems with the water to my washer it takes about 2 hours to do a full cycle. I don't know what kind of well or the water level. I don't know what kind of pump it is. I just really need major help. Is this something I can help my husband fix or do I need to hire a professional?
  2. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    You need to find out where the holding tank is because that is more than likely your problem. Either the inlet of the tank is clogged or its waterlogged. If you dont have a holding tank, one needs to be installed with a pressure switch and relief valve mounted in front of it. I have only come across one system without a holding tank and for some odd reason the pump lasted 3 years.
    Sammy
  4. bqz
    bqz New Member
    Dec 3, 2007
    Question for you, how about the other house does it have the same problem?
    If they don't have the same problem repost and let us know,secondly if they don't have the problem do they have a pressure tank?
    Do you have a pressure tank?
Similar Threads: Pressure Water
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Feb 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure trouble shooting Nov 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Complete redo of water plant - replace pressure tank with CSV Oct 17, 2016
