No Plumbing Vents
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bob(not a plumber), May 21, 2010.
  1. Bob(not a plumber)
    Bob(not a plumber) New Member
    May 17, 2010
    BC, Canada
    I am doing a little basement renovation involving a little bit of plumbing for a friend. His basement has a suite in it. This was added in long after the house was built. Part of the renovation we are doing is moving the laundry from one room to an adjacent room. When I pulled the washer outlet hose out of the drain, raw sewage gas filled the air, GROSS. I pulled of the wall paneling to see a 2 inch line coming off a horizontal drain on a 45 degree elbow stubbed out of the wall. No trap. I cut the line back in the wall, and added a 2" to 1 1/2" reducer, a trap and a drain running up the other wall for the relocation. Now the drain sucks air through the trap when any thing downstream in the suite is draining. You can here it bubbling in the trap. Obviously there are no vents in the suite, and it was using the washer drain as a vent. The next fixture downstream from the washer is a kitchen sink. Would it help to put an AAV under the cabinet between the wall and the p trap? I can see down the back of the wall from the laundry. The drain runs vertically from the washer all of the way down the wall with the kitchen sink teed off of it, and then it disappears at the far wall. There is no drop from the sink, to the drain, and no vents to be seen.
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    You may need to add TWO cheater vents to the system. I am trying to picture what you described but it's not working out well for me :p
  4. Terry
    Aug 17, 2004
    Every trap needs a vent. So count up how many plumbing fixtures you have, and that's how many vents you need.
    Simple.
    The vent is downstream from the p-trap.
    There are also distance limits on where the vent can be.
    If it's too far away it won't vent correctly.
    A. If you look on your roof, you will see pipes sticking out of the roof aprox 12" high. For every pipe that goes down, one needs to go up. The obvious reason we have vents is that sewer gases need to be vented outside of the dwelling. Not so obvious is what happens if they are not included in the waste and vent design. Imagine yourself at McDonalds drinking a soda from a straw. If you put your thumb over the straw, you can pull liquid up from the cup. Remove the thumb and see it instantly drain out! When liquid goes down a pipe, air needs to follow it. Without the vent pipe, the draining liquid will try to suck air through the P-traps on the plumbing fixtures,(tub, sink, etc.) glurp, glurp! If it manages to do so, you may know it from the "smell" coming from the now dry seal on the P-trap. Without vents, draining one fixture may cause another fixture in the house to back up, yuck! A waste and vent system should keep sewer gas out of the dwelling and drain every fixture well.
    Helpful Plumbing Hints for Residential Construction by Bert Polk Plumbing Inspector Lincoln County
  5. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    Well not exactly. You can wet vent things and save on venting. I find, through reading this forum, that our codes regarding wet vents are much more forgiving then down in the states. For example pretty much every bathroom built in Canada is wet vented through the bathroom sink picking up the tub then toilet last. So you have 3 fixtures with only 1 vent going up.
  6. Bob(not a plumber)
    May 17, 2010
    BC, Canada
    Thanks Doherty for the helpfull advice. I will look for somwhere to ad a second cheater vent. As for the lesson on how a proper system is designed please keep in mind I am working on someone elses mess, I know all about that stuff, but am not asking how to redsign the whole system. I am just asking how to make it better, or functional without spending too much money and time.
  7. jimbo
    jimbo Plumber
    San Diego, CA
    Trust me....Terry is a #1 proponent of wet venting, and I am sure he means you need venting on each fixture, but not necessarily 1 to 1 pipe out the roof. What we usually see here in S. Cal. is one pipe out the roof per bathroom, and sometimes 1 per two bathrooms if they are back to back, plus one from the kitchen, and the laundry is tied in wherever is appropriate. Wet venting the bathroom group is the norm.
  8. Bob(not a plumber)
    May 17, 2010
    BC, Canada
    I put an AAV under the kitchen sink and it seems to be working better. Upon further inspection the bathroom that is downstream is vented. The trap at the washing machine is not drawing air in, so although it is far from an ideal setup, I am OK with it. Thanks for the tips on venting.
  9. Terry
    Aug 17, 2004
    Here are some ways fixtures are wet vented.
    The fixtures are on the same floor.
    You can't dump a bathroom or sink on the second floor into the first floor vents.
    [​IMG]
  10. hj
    Many DIYers assume all you need for a "wet vent" is a pipe with water flowing through it. HOW you install the wet vent, (or any vent for that matter), is MORE important and often determines whether it is REALLY a vent or is merely cosmetic. Did I read that right that you put a reducer on the washer drain and used a 1 1/2" trap? And HOW did you convert from the 45 degree drain TO the trap? Did you put a VENT on it, which that description would have required?
Similar Threads: Plumbing Vents
Plumbing Forum, Professional & DIY Advice Raising the roof.... Eh herm, ceiling. Advice moving plumbing and vents. Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Adding in missing plumbing vents Dec 19, 2015
Plumbing Forum, Professional & DIY Advice Plumbing Vents on My Roof Jul 11, 2014
Plumbing Forum, Professional & DIY Advice Old mobile home plumbing; lack of vents Jun 1, 2013
Plumbing Forum, Professional & DIY Advice Plumbing Vents and Solar Installations Mar 29, 2013
