Ron Jarrett
I have a 1 hp 25 gpm pump in a cistern with a franklin no load sensor for 1/2 to 1.5 hp. 20 years old. The no load sensor is shutting off after a minute or so when the pressure tank gets to around 50 psi. Pressure switch is at 35 to 55 psi. Have an 85 gal pressure tank that I think takes about 25 gallons from low to high pressure.
The contact point on the no load sensor is getting black but can't see how that would make it shut the pump down. It takes slightly more than a minute for the pump to fill the tank. For now have bypassed the no load sensor and was going to order a new one. How do I tell if the problem is with the no load sensor or the pump motor?
