No lights
Discussion in 'Electrical Forum discussion & Blog' started by Jed54, Feb 7, 2008.
  1. Jed54
    Jed54 New Member
    Apr 4, 2007
    First of all I hope I can explain this correctly.. If not.. I tried.. Here we go.. My cousins home lost power to the second floor.. The second floor still has all knob and tube.. Going upstairs there is a section of 12/2 wired nutted to three knob & tube wires.. One to black, one to white, and one to the ground.. This one line feeds the entire second floor.. or did... I went downstairs to basement and found this 12/2, and discovered that this was spliced and taped to the knob & tube. But the ground wire is not coming from this section of 12/2. Its cut cleanly from the sheathing.. Back upstairs to first floor there is a duplex near to the 2nd floor stairway which I took a meter, and put probe into the neutral side of outlet, and checked the power coming from 12/2 upstairs, and it showed 120 volts on one line, and 80 volts on second. Meter test cables were just long enough.. Which then showed there is voltage present, but somewhere a neutral is dropped.... This also killed the power to the first floor ceiling fan in dining room..Anyway.. I know this description is goofy, but any insight would be appreciated..... Thanks everyone.. ;)
  2. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    If you have a digital multimeter, you may be reading induced an voltage (80V) and there isn't any current on the wire. A small lightbulb might be better to test with. You should get 120V between hot and ground and hot and neutral and zero volts between ground and neutral.
    Personally, I've never seen K&T wiring with a ground.
    You'll need to map out the whole K&T run and deduce where things are going. It's usually pretty tough, especially with three way lights and fly-away splices leaving different places and meeting up somewhere else. After you have a map, then you can troubleshoot.
    Personally, I'd use this oppurtunity to upgrade the wiring to meet todays code.
    I do not know the proper way to splice nm/thhn to the ruibber coated K&T, but I would think it would be wire nuts and not just tape. K&T to itself is actually soldered and taped, not just taped.
  4. Jed54
    Jed54 New Member
    Apr 4, 2007
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    I suggest you seek help from an electrician who can see what you have
Similar Threads: lights
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
Electrical Forum discussion & Blog 3 recessed lights, switch at end? May 9, 2015
Electrical Forum discussion & Blog Retrofit Recessed lights with LED Dec 3, 2014
