No hot water in Master Suite ONLY!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mtinrunner, Jan 20, 2010.
  1. Mtinrunner
    Mtinrunner New Member
    Jan 20, 2010
    CA
    As the title suggests The Master only has lost hot water twice now. The MS has water flow but no hot water. After 2-3 days it comes back on. any ideas? thx
  2. jadnashua
    Some shower/tub control valves and even sink single-handle valves can develop a cross-over. This can provide a short-circuit to either hot or cold water...it's usually the hot since it has more restrictions through the water heater - the cold wins and flows through. When this happens, shut off the supply to the sinks or ensure that the control is set to the full-hot or full-cold side (if possible) and see if it clears up. If you find the offending valve, replace the cartridge. This assumes you get flow, but no hot. If the flow shuts off, that's another thing altogether.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Frozen pipes?
    I don't know your weather conditions where you are.
  5. Mtinrunner
    Jan 20, 2010
    CA
    thanks jadnashua... I was born in Nashua and lived in Hollis. Been in Northern CA Bay area since the 70's hence no frozen pipes. We lost the hot water throughout the house two days ago and ended up being the thermal coupler. Doesn't seem related? but I'll try your suggestion if we lose hot water in the MS again.
Similar Threads: water Master
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Lukewarm water in Master shower/lavatory Jan 17, 2014
Plumbing Forum, Professional & DIY Advice Hot water in master sinks not working Dec 9, 2009
Plumbing Forum, Professional & DIY Advice City water master cutoff! Feb 22, 2009
Plumbing Forum, Professional & DIY Advice Hot Water Setup / Master Shower Jan 22, 2008
