No Hot water from shower - Single handle knob
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mawk, Jun 29, 2009.
  1. Mawk
    Mawk New Member
    Jun 29, 2009
    Hello,
    In our secondary bathroom, our shower/tub has a single handle knob and when turned to HOT no hot water comes out at all and it just shuts off the water (it drips just a little bit when on full HOT, and that water is also NOT HOT). It is a condo unit and it used to work just fine and this particular shower has seen very little and infrequent use. All other faucets work perfectly fine in the condo.
    [​IMG]
    [​IMG]
    What do you think the problem is and how can I fix it myself? Thank you for any and all help!
    -Mike
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
  4. Mawk
    Mawk New Member
    Jun 29, 2009
    Is this located right behind the circular plate behind the handle? How do I get to the balancing spool?
    Thanks for your help!
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Do you have a plumbing shop in your area that deals with DIYers? These guys are knowledgeable about the products and are very willing and able to show you what to do. You may occasionally find a "smock man" that can do this, but usually at a Box store you just find sales people. Actually, once the cover plate is removed, you should be able to pretty well figure out what to do next.
  6. Mawk
    Mawk New Member
    Jun 29, 2009
    Not sure if there are any plumbing shops in my area for DIY'ers, but I could look into that. My next question is, do you have any tips on how to remove the circular plate without damaging the shower wall? It appears that the outside edge (all around) is sealed al to the shower wall with some calking or something similar. Forgive me for the cautious newbie question :).
  7. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Take a sharp razor knife and gently cut around the silicone at an angle so that the blade is cutting in towards the valve under the plate. This way you'll avoid damaging the surround.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You may find it very easy to turn a small job into a big one...
    There is a nut that holds the cartridge in that if it is hard to remove and you twist too hard you can ruin the valve.
  9. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Yes, yes you can... :(
Similar Threads: water shower
Plumbing Forum, Professional & DIY Advice Broke my cold water stem for my shower. Options? Feb 14, 2017
Plumbing Forum, Professional & DIY Advice water leaking shower room condominium Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
