No hot or cold water from bathroom faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Canuck Fan, Dec 18, 2010.
  1. Canuck Fan
    Canuck Fan New Member
    Dec 18, 2010
    Langley, BC
    My neighbour is an older guy who isn't very handy and he asked if I can do him a favour. His bathroom faucet was dripping slowly but constantly and he asked if I could have a look at it as I'm an apprentice plumber (no service experience thought, just over a year building highrises) I figured that the rubber washer on the end of the cartridge was likely worn so I said no problem. I took both cartridges out and replaced the rubber washers (they did look ok but had a circular indent on them, I assume where they seat)
    After reinstalling the cartridges, only the tiniest dribble of water comes out of the tap for either hot or cold. If I pull either cartridge and turn on the stop in the cabinet, loads of water comes out the hole the cartridge was in.
    Ideas???
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    You do not repair a cartridge !
    You replace it !
    The worlds first plug and play unit that came along in the 70's to be easy to fix just by
    replacing the cartridge
  4. hj
    How about removing the aerator from the end of the faucet and cleaning it or replacing it? Bad
    "cartridges", and I assume these are American Standard AquaSeal stems, ONLY prevent water from one side or the other, and it would be unusual for BOTH to fail at the same time. IF you turn on the cold and only get a little bit of water, and then turn on the hot and the flow does NOT increase, the blockage is PAST the point where the two come together, and the aerator is usually the only spot that happens.
Similar Threads: cold water
Plumbing Forum, Professional & DIY Advice Broke my cold water stem for my shower. Options? Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Cold Water Line to Kitchen not Working Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Cold water relief valve question Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Cold water supply line connected to cast iron main stack? Oct 27, 2016
