Hello all. I recently replaced an old small cast iron radiator in my second floor bath with a runtal wall panel. They look very restrictive to flow so before I ordered it I did some crude calculating and figured the flow rate would be lower but doable. I bled the system and ran it for at least an hour and this thing just doesn't get warm at all. In fact the supply pipe for it in my dining room only gets hot a third of the way up. I removed it, opened the valves and checked for obstructions which there weren't any. All the other radiators in the house get hot, albeit at drastically different rates because of large iron piping that was replaced by the previous owner with 3/4" copper in some spots including the bath I'm working on. For instance, two of the second floor rads and one on the first floor get hot real fast while everything else is just getting warm. The boiler is operating at 15psi so I know that's good. I'm thinking the system needs some serious balancing to get this rad to work but I'm a bit apprehensive about doing it considering some of the valves look like they haven't been turned in decades. Anything else I should try before biting the bullet and repiping again to put traditional iron rad in? Thanks
