No floor drain for softener
Discussion in 'Water Softener Forum, Questions and Answers' started by Tyler Padgitt, Mar 27, 2013.
  1. Tyler Padgitt
    Tyler Padgitt New Member
    Feb 20, 2013
    Hey guys I just got a Marlo water softener. I have no floor drain for it and send the discharge overhead. What should I do for the brine tank overflow line? Stick it in a 5 gallon bucket?
  2. Gary Slusser
    Retired
    Most people don't do anything with it. Wise people check the salt (and water) level like weekly to catch a problem before they have salt water on the floor.
    A 5 gallon bucket may over flow also. It depends on how long water flows into it.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Most systems use a timed refill and include a safety float in the brine tank for proper redundancy to prevent water from overfilling the brine tank due to a power failure during refill, or a leaking and worn brine valve.
    The gravity overflow is rarely connected unless the system is installed in a highly water sensitive area.
    Softeners should not typically be installed in highly water sensitive areas without proper floor drainage in case of a leak.
  5. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
  6. Tyler Padgitt
    Feb 20, 2013
    Can anyone confirm that a Marlo Water Softener has a Fleck head? I was told it does.. Or at least that Fleck makes the heads they use?
  7. Tyler Padgitt
    Feb 20, 2013
    Bumping this to find out if Marlo heads are made by fleck...
  8. Gary Slusser
    Retired
    You can go to www.fleckcontrols.com and look at some pictures and see if yours matches any of their valves.
    But if you find one, it may look like as if you have a Fleck whatever but... yours may have a part or two that is proprietary to only Marlo.
Similar Threads: floor drain
Water Softener Forum, Questions and Answers Water Softener Drain - Do we need a Vent for a Floor Drain or ? Jun 19, 2016
Water Softener Forum, Questions and Answers Can I drain my water softener in a floor drain? Mar 13, 2013
Water Softener Forum, Questions and Answers Discharge tube disconnected, saw some resin beads on the floor...what could this mean? Jun 25, 2015
Water Softener Forum, Questions and Answers Kinetico experts - water leaking to drain Mar 16, 2017
Water Softener Forum, Questions and Answers Question about new softener and Drain Install Mar 14, 2017
