No flange on the drain for toilet replacement!
Discussion in 'Toilet Forum discussions' started by chetwynd, Jul 27, 2005.
  1. chetwynd
    chetwynd New Member
    Jul 27, 2005
    California
    Hi guys,
    Thanks in advance for the help. I'm kind of an amateur plumber and I know some of you hate that, but I'm trying to learn!
    I went to install a toilet at someone's house, and when I took a look, there was just a 4" drain sitting in the floor, with no flange! As in, just the pipe itself sitting there flush with the finished floor, but no flange, nothing to bolt down to. What do I do? Any help is much appreciated! : :confused:
    Also, can anyone recommend any good books that are good for learning plumbing...specifically drains and vents? Copper and gas I'm cool with, but drains and vents I'm a little hazy on.
    THANK YOU!
  2. slb
    slb New Member
    Jun 17, 2005
    San Francisco North Bay
    If the drain pipe is ABS or PVC, I know that there is a flange that slips inside of a 4" drain. That would be the easiest to install. If the pipe is cast iron, I think there is a flange with some sort of expansion mechanism that inserts into the drain pipe. Wait for one of the experts to chime in, they'll have the specifics.
    -Steve
  4. chetwynd
    chetwynd New Member
    Jul 27, 2005
    California
    thanks!
    :D Thanks Steve, I'll see what the others have to say too. I figured there's something like that. I actually forget if it's ABS or iron or what. The problem is that when I go look at these jobs, I have to pretend like I'm some bigtime plumber, so I don't stare at stuff too long or the customer will wonder what the hell my story is!
  5. hj
    flange
    I would guess that you are more an amateur handyman than a plumber, and I wonder what your "customers" would say if they knew you were learning on their jobs? In this area plumbing without a license is a felony, and the contractor's bulletin board is full of pictures of men who are either being hunted, or arrested, for working without a license. There are many ways to install a flange, but you have to know the material, pipe size, and how the pipe is installed in the concrete to determine the best way to do it.
  6. chetwynd
    chetwynd New Member
    Jul 27, 2005
    California
    Thanks again...
    I have my plumbing license. In addition to my General, and Electrical. Do you have those as well? If you would like to have the contractor's board call me and discuss my licenses, please do. Where else am I going to learn other than practicing and talking to experienced folks like the kind you?
    Oh, and by the way, it's only illegal to do a job over $500 total AND to be unlicensed. This particular job is under $500, AND I'm licensed, so I hate to burst your bubble.
  7. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Whoa there. No need for anyone to get unruly. :D Since you said that you were learning plumbing as you went along, I believe HJ (who probably has more plumbing experience than 95% of the posters on this board) brought up some legitimate points. I do wonder how you have a plumbing license without a firm grasp of the trade, but frankly its really not any of my concern and I dont give a rats hiney about it. :cool:
    Now on with the show........
    A 4X3 PVC toilet flange will glue inside a 4" pipe. I'm sure they make the same in ABS (we dont use ABS here in Cincinnati). In addition, Oatey makes a flange that slips inside 4" cast iron pipe. The seal is made by tightening 3 allen head screws thus expanding the elastomeric seal inside the pipe. One of these type of flanges should take care of the problem for you.
    Good luck and happy plumbing
  8. hj
    flange
    I am glad to hear you are licensed, but the next question would be, if so, why did you have to ask the question in the first place. The reason for my comment was that the majority of "learning plumbers" do not restrict themselves to $500.00 total jobs, nor do they avoid jobs, such as water heater replacement and water repiping, which require both a PERMIT, (not allowed by the handyman exemption), and a plumber's license.
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    flange
    right on hj..............you dispense lots of good advise
  10. jimbo
    jimbo Plumber
    San Diego, CA
    We have several recommendations about types of flanges which might be available to attach to your pipe. The issue which might be a problem is can you get a flange on there and have it sit low enough to not rock the toilet. This will partly depend on the surrounding sub-floor. Is it concrete, wood, etc. Take a picture of it, and take the picture to a plumbing supply house. They know what's available and what will work for you.
  11. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    Wow.. if it's that easy to get a plumbers license.... maybe I should apply!
Similar Threads: flange drain
Toilet Forum discussions Help! Broken flange that was resting on crumbling mortar, bolt down drain!! Sep 15, 2016
Toilet Forum discussions Saniflo Sanicompact drain thru wall to toilet flange in other room? Sep 2, 2015
Toilet Forum discussions Help connecting a PVC toilet flange to an existing brass drain Jul 23, 2013
Toilet Forum discussions Drain flange for tile floor Jul 24, 2012
Toilet Forum discussions Gap between toilet drain flange and bathroom floor tile Sep 24, 2011
