No Drain Valve on my Space Saver Water Heater??
Discussion in 'Water Heater Forum, Tanks' started by Napolean, May 11, 2014.
  1. Napolean
    Napolean New Member
    May 11, 2014
    Ontario
    I need to change my water heater but can't seem to find a drain valve on it. The hot and cold connections are connected in the front not on the top of the unit. How do I drain it to change it. Its a GSW Series 5 tank? Any help would be appreciated.
  2. jadnashua
    You may just have to cut the pipes and drain it into a bucket. I tried to get onto the GSW website, but it appears to be down at the moment. How many gallons is it? Water weighs about 8#/gallon, and the tank itself is probably not much if it's in the space saver series.
    Is there a plug in the thing? If so, it will usually have a square stub sticking out you should be able to get a wrench on.
Similar Threads: Drain Valve
Water Heater Forum, Tanks Question concerning water heater drain valve. Dec 21, 2016
Water Heater Forum, Tanks What size threads are used on drain valve (Rheem Fury elec. WH) Jul 17, 2015
Water Heater Forum, Tanks Connection to drain valve? May 12, 2015
Water Heater Forum, Tanks Water heater relief valve drainage Mar 10, 2015
Water Heater Forum, Tanks Bradford White RTV-75 Drain Valve Sep 13, 2014
