no cold water from shower
Discussion in 'Shower & Bathtub Forum & Blog' started by patvoyles, Aug 18, 2008.
  1. patvoyles
    patvoyles New Member
    Aug 18, 2008
    I have a single shower valve with no identifiable mfr name.
    no cold water comes out of the valve unless you turn the hot water tank valve off and open both spickets at the sink which shares the same supply pipes.
    when you take the cover off the shower valve you can see a screw valve on each supply line feeding the shower valve. both of the screw valves are in the full open position.
    If you turn the hot water tank back on the cold stops coming out of the shower head and is replaced with hot only.
    I also removed the shower valve and it appears clean.
    Thoughts?
  2. patvoyles
    Aug 18, 2008
    test
    testing response
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It sounds like a stuck pressure balancing spool. The method of repair depends on the make/model of the valve.
    I would suggest posting a picture of the valve.
  5. patvoyles
    Aug 18, 2008
    is the pressure balancing spool contained within the cartridge?
  6. Redwood
    Dec 15, 2007
    Service Plumber
    It depends on the make and model of the valve. Can you post a picture of it?
Similar Threads: cold water
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog shower not mixing enough cold water Apr 11, 2015
Shower & Bathtub Forum & Blog Shipping Shower Waterproofing in cold weather: How to protect from freezing Oct 17, 2014
Shower & Bathtub Forum & Blog Hot water reduced to trickle in shower - cold water works fine Jun 24, 2014
Shower & Bathtub Forum & Blog No cold water in shower Jun 1, 2014
