No clearance between tank and wall
Discussion in 'Toilet Forum discussions' started by newbrain, Sep 25, 2011.
  1. newbrain
    newbrain New Member
    Sep 25, 2011
    MA
    We are installing 5/8" AZAK beadboard to bathroom but our toilet tank abuts the wall - zero clearance. This is my first post so I need help. It is a 12" rough in with a Briggstoilet 1.6gpf/6 Lpf.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    It seems lile you have two choices. Either replace the toilet or cheat it forward a little. My American Standard toilets centred on a 12" rough-in have more than an inch of clearance behind the tank.
  4. hj
    "Cheating the toilet forward a little" can create many problems. Get a toilet which does NOT need the full 12", assuming your pipe in the floor IS at exactly 12".
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It may not be good form to dis your choice of toilets, but the Briggs are really not a recommended toilet by most of the pros on this forum, so if a new toilet is in your future, why not go with a high quality one. The rough-in number can be very confusing. Most toilets require less space than their listed rough-in size. For example, I have 2 Toto toilets, different models, that are on 12" rough-in flanges. Exactly 12". There is approximately 2" space behind these toilets. I would suggest to you that this would be a good time to greatly improve the quality of your toilet, and meet the remodeling needs at the same time.
  6. jadnashua
    Unless the toilet is used repeatedly so the incoming water to the tank gets cold enough to cause condensation, it won't cause problems with the tank touching. Most newer toilets do not evacuate all of the water in the tank, so often, it is room temp, then add some cold, it may not get below the dew point and condense as they mix. The outlet of the toilet is smaller than the opening in the toilet flange, so you can safely get at least 1/4" or so while still having the toilet's outlet pointing down the flange and still be able to anchor the bolts. It becomes a major problem if it isn't, though. You also must ensure you get a good wax seal, and shifting it too far will potentially prevent that from happening, so moderation is the key.
  7. newbrain
    newbrain New Member
    Sep 25, 2011
    MA
    great advice
    Thanks Gary for the advice. We had Toto toilets when we were in NC. This one came with the house. Thanks to all for your suggestions. Great forum!
Similar Threads: clearance between
Toilet Forum discussions Trouble replacing valve in minimal clearance skirted toilet Dec 4, 2016
Toilet Forum discussions Buying clearance with 14" unifit and offset flange Aug 8, 2016
Toilet Forum discussions Low Clearance Toilet Options Dec 31, 2014
Toilet Forum discussions Question for Terry or the other Pro's...Guinevere Wall clearance Nov 2, 2013
Toilet Forum discussions Toilet under extended countertop, clearance issue. Oct 11, 2012
