No Ceiling Joist available for wall???
Discussion in 'Remodel Forum & Blog' started by thezster, Jul 18, 2005.
  1. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    My remodel continues.... While I've done lots of remodel work before - It's never been in a basement. Due to overhead HVAC and water/electric lines, I don't have ceiling joists to attach a couple of my walls to at the top. I plan to shoot braces into the concrete walls and attach those to my new wooden walls every couple of feet. Kosher???
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    These are not load bearing walls, so anyway that will work is OK. A method of anchoring to concrete that I have found fairly easy is to use a hammer/drill, lead ferrells, and screws. What I do is to cut the 2x4 to size abd drill holes in the where I want to put the screws. Then hold the board in place and drill into the concrete using the board as a template. You can do one, then put the ferrell in, screw the board to the wall, position it for square, and drill the rest of the holes. Then swing the board aside to access the new holes. I also use screws for most of the carpentery work when doing this kind of job. Sure makes it easier working in places where you can't swing a hammer not to mention being able to easily remove and reposition if you get something out of place. I invested in an inexpensive rotary/hammer drill for these kind of jobs. Sure is a handy tool even if it isn't one I use everyday. (Something like $100 including a few bits and chisels)
  4. thezster
    thezster New Member
    Jul 18, 2005
    Thanks Gary... I ended up using a $40 Remington "shooter" to anchor.... Works great.
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    That works too, it's just harder to deal with if you should have to change anything.
Similar Threads: Ceiling Joist
Remodel Forum & Blog What does the ceiling edge attach to when the wall is between joists? Jan 3, 2005
Remodel Forum & Blog Basement Ceiling - Typical Sound Reduction Steps Feb 29, 2016
Remodel Forum & Blog Non-load bearing wall with vaulted ceiling? Jan 10, 2016
Remodel Forum & Blog Faux Beam for Cathedral Ceiling Nov 6, 2015
Remodel Forum & Blog Has anyone ever follen thru the ceiling? Jul 29, 2014
