No-Barrier Shower Base/Receptor/Stall
Discussion in 'Shower & Bathtub Forum & Blog' started by stephenson, Jan 29, 2012.
  1. stephenson
    stephenson Member
    Oct 18, 2011
    Northern Virginia
    Last post on same remodel was related to drain issues and potential for all tile wet room concept.
    After considering concrete excavation and time issues (never enough), I am now considering a receptor with very low (3/4" or so) lip (I don't want a "ramp," just an extended lip) ... problem is that I can't find many choices ... appears to be a specialty item with few manufacturers ...
    http://www.barrierfree.org has a few examples, but everything is pretty much ship to order - would appreciate info on manufacturers ...
  2. jimbo
    jimbo Plumber
    San Diego, CA
  4. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Check with a cultured marble installer.
  5. stephenson
    stephenson Member
    Oct 18, 2011
    Northern Virginia
    Thanks, Jimbo ... the schematic shows a 7/8" lip, but it looks vertical and is designed to connect up to the ramp ... while this works, it looks to be an ad hoc way to solve the problem ... have seen at least one design with a complex angle approach for the lip that looks like it would keep water in pretty well ...
  6. stephenson
    stephenson Member
    Oct 18, 2011
    Northern Virginia
    Just found another supplier - American Reinformed Plastics - Tacoma ... Model# S-6034-BFP ... 1 1/2" lip from outside, but 3/4" of that would be eaten up by the adjoining tile work ...
  7. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Check out the AKW line.
    Very low build up and with a little 1/2" cement board outside the shower you can build a barrier free shower.
    JW
  8. stephenson
    stephenson Member
    Oct 18, 2011
    Northern Virginia
    Just found another - comfortdesignsbathware.com ... several shower solutions - don't know if the base can be used a s standalone receptor, yet.
  9. stephenson
    stephenson Member
    Oct 18, 2011
    Northern Virginia
    Found another supplier - Aker by Maax ... enclosures only, and a bit simpler design with a 2" vertical lip ... the tile will take about 3/4 inch so should be able to still roll over the lip. Probably not ADA compliant, but functional and may be better at retaining water inside.
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    You do not want a lip of more than 1/2" if you plan to roll in.
    Schluter makes a ramp for tile.
    1 1/4" elevation change will need a tapered ramp a good 2' 1/8" to make rolling in easy. If the lip is on the inside you will not be able to get out or possibly even turn to your right or left.
    Be careful with this and make a test rig before purchasing.
    A custom tiled shower or a pan like I mentioned from AKW is a much safer bet for a better preforming shower.
    JW
  11. stephenson
    stephenson Member
    Oct 18, 2011
    Northern Virginia
    So, after checking out all the options, I had to eliminate Mustee (can't find a center drain in their line of low/no barrier), AKW (availability issue here likely related to shipping costs) ... further, after laying out on the floor, I really need a 30" depth to avoid interference and at least 60" length to allow suitable entry access. The only 30-32" depth one is from BestBath, and they have 3/4"-2" threshold lips - if I were to go with 2", the tile would net it out to a bit over 1" ... which would still be OK - not ADA compliant but the shower will not be for "independent living."
    Since I can't install an entire system with membrane, etc, perhaps the 2" would be best approach - it is going on concrete floor ... I understand the risks and will take extra care on sealing, etc.
  12. udsexpert
    udsexpert New Member
    Feb 6, 2012
    N. California
    Check out www.best-bath.com
    They have the largest selection that I am aware of and they are excellent quality with a 30 warranty included. You will need to buy from a dealer as they don't sell directly. I carry them and would be happy to assist you www.universaldesignspecialists.com or just to give you more info if you need it.
  13. Todd Stull
    Todd Stull Bathroom Specialist
    Feb 20, 2012
    Owner/Operator of Alone Eagle Remodeling, LLC
    Harrisburg, PA
    In addition to all the good sites recomended, Swanstone has a lot of Universal Design options as well!
  14. stephenson
    stephenson Member
    Oct 18, 2011
    Northern Virginia
    Just got finished ...floor remodel done except for speakers, etc ...ended up using a Laskey (now Aquatic) located in South Boston, VA ...went to plant as it was near the house ...very nice products...got one of their low lip receptors and it installed no issues ...had brass drain connector fitting with it, even. Lip was kind of graduated, but front edge was only 3/4" so was perfect. Nice acrylic finish and very substantial with fiberglas structure.
Similar Threads: No-Barrier Shower
Shower & Bathtub Forum & Blog Need help in identifying shower faucet Yesterday at 6:36 PM
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Wednesday at 2:58 PM
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
Shower & Bathtub Forum & Blog Sterling shower panel with crack Sunday at 4:55 AM
Shower & Bathtub Forum & Blog Moen Chateau, Which shower trim fits this valve? Mar 16, 2017
