Niagra toilets
Discussion in 'Toilet Forum discussions' started by hijarhead, Mar 28, 2007.
  1. hijarhead
    hijarhead New Member
    Mar 28, 2007
    Installed a Niagra toilet about two months ago. It has a "pan/bucket" in the tank that fills with water about 1/2 gal I would guess. When you turn the handle to flush,the tank/holding pan emties into the tank flushing the bowl. Comes with a "life-time" guarantee that it will never have a run/drip problem that flappers cause. Anybody used or have an opinion on this unit.. So far I have no problems ( of course I realize this is a short amount of time). thinking on using them on other projects just want to make sure they are reliable.
  2. Terry
    Aug 17, 2004
    The water tray holds water that is dumped for flushing the toilet, instead of the flapper that you normally see.
    As we all know, flappers can gio bad and leak.
    In that regard, the water tray of the Niagara reduces that area of repair.
    Not that you are totally home free though. There are still handles that can break, and trays that can crack.
    It uses the Fluidmaster repair parts for the fill valve.
    http://www.coopershardware.com/store/products/Fluidmaster-703A5B.html
  4. Cass
    Cass Plumber
    Nov 12, 2005
    I installed 1 reciently and it tested O.K. but over the long haul I don't know, and how it performs under a "heavy load" is unknown to me.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I installed one for a friend and the handle broke within a week. Niagara sent one free, but it took 3 months to get it because they were on backorder. You may want to order a couple handles in advance from them if you're going to install a lot of these.
    I think this design will eliminate the problem of tank condensation in humid areas.
Similar Threads: Niagra toilets
Toilet Forum discussions Stealth toilet by Niagara, Niagra Jan 10, 2011
Toilet Forum discussions Niagra Flaperless Profiency Feb 18, 2010
Toilet Forum discussions On the Canadian side of Niagra Falls........... May 20, 2008
Toilet Forum discussions Niagra Flapperless Nov 16, 2006
Toilet Forum discussions Older toilets are gold! Jan 13, 2017
