My home requires a lift pump for local municipal water to reach the house. Static water level of the municipal supply is about 60 ft below my house. I need to have around 20 GPM at the house, so need to understand how to evaluate pump curves for the situation.
Next, the existing lift pump system is a 25 GPM, 3 HP Jacuzzi, located within an existing pump-house. The existing pump (so far not the motor) is failing (leaky seals and perhaps worse inside), and the pumphouse (large-size, 8 x 12 ft, don't know why) must be replaced. In addition, the current installation requires a separate meter (cost of around $25 per month just for the meter). Actual electricity usage is minimal, only around $3 per month. Existing plumbing is 2" PVC from the meter to the pump-house (around 40 ft), then a large-ish pressure tank (120 gallon?) with the existing pump, and then around 700 ft of 2" PVC to reach the house.
I want to change this to something less difficult and expensive to maintain and operate. This would probably be a "can" or sealed cistern to replace the pumphouse, which would keep everything below ground, with a submersible pump in the can. This eliminates freeze-protection issues, as well as the monthly meter charge. The small problem with this is that to power the unit from my house will require 400 to 700 ft of wiring (one direction).
The water-system guy recommend a new Jacuzzi VFD system (no specific pump or motor at this point) as a submersible pump in the can.
My specific questions about this setup are as follows:
1. How do I use the pump-curves to choose the most appropriate pump?
2. Am I right that a 3-phase motor is probably better in this situation?
3. Can I find an affordable 3-phase converter without having to spring for a VFD controller that I won't likely use?
4. How do I size the proper cycle-stop valve for this situation? I would locate it at the service entrance (water that is) for the house, not at the pump.
5. Anything else I should be aware of to achieve the best system for my situation?
Many thanks in advance for help with this, and if any of these questions can be easily answered by referring to another thread, please just point me there instead.
