SeanFraizer
This is my first home with a well and since day one there has been a clicking/chattering sound coming from the pressure tank whenever the pump switches on. It is not the pressure switch (that clicks on once). I'm thinking it is the check valve installed before the pressure tank? I've purchased a new check valve, but the fittings are all extremely stuck. Before I start attacking them I was hoping to get the opinions of the experts on this forum.
Also, the pressure switch is reading roughly 4-5 PSI higher than the tank. I have drained the tank and measured an empty pressure of 38 PSI. The switch is supposed to cut in at 40. However, it is cutting in closer to 45 and cutting off at 65 (although the tank only reads 60) Any ideas? Bad switch, bad gauge? Should I adjust the cutoff on the switch or replace it? I'm fairly handy and would like to avoid calling in the pros if at all possible.
Any suggestions would be much appreciated!
